29F2G08ABAEA The copy is not working.
musgokce | Дата: Суббота, 2017-03-18, 14:46 | Сообщение # 1 |
| I am running nand flash, I am writing another nand flash, the device is not turning on. I am experimenting with a few boards that have a solid flash of data. I did not do reading and writing with tnm5000, I did not do it with rt809fpeb-1. Flash: 29F2G08ABAEA Led tv model: 60le652 sharp Why can it arise?
onkyo | Дата: Воскресенье, 2017-03-19, 10:15 | Сообщение # 2 |
| Please describe in detail the defect. Where did you get the firmware? Is there a bad block in the chip, and how much? I'll look at the firmware.
musgokce | Дата: Вторник, 2017-05-23, 17:53 | Сообщение # 3 |
| Hello, sharp 39le752 or 50le752 (le652). I am reading the integrated flash file running, I am writing the new flash integration, it is not opening. I'm plugging in the flash card of another card. I have not read 3 or 4 running flashes, it is not. Could it be protection in the flash? There is no corrupt sector in flash integrated. I integrate the working flash file I read. I uploaded 2 files to flash integration, it does not work. Could you help?
https://drive.google.com/file/d/0B2a_e2fCC9HrajlncEJpeWVWZmc/view
