Выход новых обновлений софта программаторов TNM 5000 TNM7000
| Admin | Дата: Суббота, 2015-05-30, 10:16 | Сообщение # 31 |
| Новое обновление софта
для Nand
Nand Programmer Software version 5.95 for Model 5000 (May 28,2015)
Micron MT29F4G08AAC / 29F128G08CFABB , ESMT F59D1G81A / F59D2G81A / F59D4G81A , Toshiba TC58NVG1S3HTA00 / TC58NVG1S3HTAI0 are added. MT29F2G08ABAEA Erase & Program Bug Removed.
| Admin | Дата: Суббота, 2015-06-27, 10:31 | Сообщение # 32 |
для Nand
Nand Programmer Software version 5.96 for Model 5000 (Jun 27, 2015 )
29F32G08CFACA / 29F16G08CBACA / 29F1G08ABBEA / 29F1G08ABAEA / TC58DVG02D5TA00 are added.
| Admin | Дата: Вторник, 2015-07-07, 09:25 | Сообщение # 33 |
основной
Version 9.44 (July 5, 2015):
4094 added to TTL/CMOS ICTester Model 2000+/5000. Macronix MX25U1635F / MX25U3235F / MX25U6435F / MX25U12835F / MX25U25635F / MX66L51235F / MX66U51235F / MX66L1G45G are added to Model 5000. MC9S12XEA128MAL / MC9S12XEG128MAL / MC9S12XEG256MAL / MC9S12XET256MAL / MC9S12HY/HA series are added to Model 5000. TC58DVG02D5TA00 is added to Model2000+ / Nand Programmer Model 5000. IS62WV1288ALL / IS62WV1288BLL are added to SRAM tester.
| Admin | Дата: Суббота, 2015-09-26, 08:59 | Сообщение # 34 |
| Новое обновление софта.
Теперь программатор TNM5000 , поддерживает ENE KB9018
Version 9.50 (Sep 25, 2015):
ENE KB9018 / MX29LV128DT / STM32F103C8 / STM32F103CB / STM32F10+3R8 / STM32F103RB / STM32F103V8 / STM32F103VB are added to Model5000 Renesas uPD70F3740 /uPD70F3743 / uPD70F3744 / uPD70F3745 / uPD70F3746 / upd70F3477 MC9S12G96 / MC9S12G128 Flash / EEPROM is added to Model 5000. MC9S12XDG128MAL is added to Model 5000 , 9S12XD128 Memory addressing system is changed to Logical Paged Model. MK48T02 / MK48T02B / MK48T08 / MK48T08B / MK48T12 / MK48T12B / MK48T18 / MK48T18B / MK48Z02 / MK48Z08 / MK48Z09 / MK48Z12 are added to Model5000 /2000+. ATMEGA8U2 / ATMEGA16U2 / ATMEGA32U2 are added to Model5000 /2000+. AMD AM29LV065D tsop48 ia added to Model5000. Chip Unique ID show is added for winbond 25xxx-Security in config Window (Model2000+ / Model5000) . SANYO LE25U40CQE / LE25FU206A are added to Model5000 /2000+. SST39VF040 Erase/Program Bug, W25Q256 Write Bug / M6M80021 Bug are removed.
| serg2000 | Дата: Пятница, 2015-10-30, 20:01 | Сообщение # 35 |
| http://www.tnmelectronics.com/UpdateProgrammer.html следующий апдейт, вот только что добавили в него я не знаю
| Kodov | Дата: Вторник, 2015-11-03, 08:32 | Сообщение # 36 |
| Version 9.52 (Nov 2, 2015): X88C64 ,MC9S12XEP100 , MC9S12XEG384 , MC9S12XEQ512 , MC9S12HZ256 , MC9S12HZ128 , MC9S12HN64 , MC9S12HZ64 are added to Model5000.
| Jagupop | Дата: Суббота, 2015-12-12, 09:01 | Сообщение # 37 |
| Уже вон 9.54 обновление появилось, а форум молчит... http://www.tnmelectronics.com/UpdateProgrammer.html
| Admin | Дата: Суббота, 2015-12-12, 10:47 | Сообщение # 38 |
Version 9.54 (Dec 9, 2015):
68HC705X32 EEPROM is added to Model5000. TSOP56 pin flashes S29GL128S / S29GL256S / S29GL512S / S29GL01GS are added to Model5000. MX25L1636E Id bug is fixed TSOP56 Bug from version 9.45-9.52 is removed (in new installation).
| Danila_iva | Дата: Среда, 2015-12-30, 00:28 | Сообщение # 39 |
| подарок к новому году похоже ... доступно 9.56 обновление основного софта от 28 декабря 2015, по изменениям пока непонятно
Добавлено (29.12.2015, 23:28) --------------------------------------------- http://www.willem-ua.com/TNM_5000/Soft/Upgrade956.rar
| Admin | Дата: Среда, 2015-12-30, 11:55 | Сообщение # 40 |
| Version 9.56 (Dec 28, 2015): MC68HC711E9 (EPROM / EEPROM) is added to Model 5000. AT25F512A / CAT25010 /CAT25020 /CAT25040 are added to Model2000+ / Model5000. GD25LQ128 / GD25LQ16 / GD25LQ32 / GD25LQ40 / GD25LQ64 / GD25LQ80 are added to Model2000+.
| Danila_iva | Дата: Четверг, 2016-01-21, 02:15 | Сообщение # 41 |
| обновление основного софта version 9.58 доступно (от 13.01.2016) http://www.willem-ua.com/TNM_5000/Soft/Upgrade958.rar
24C01-24C512 I2C serial EEPROM Auto detection on ZIF Socket (None Blank Parts) for Model 5000/2000+. PIC18F452 PLCC44 is added to Model 5000. PIC16F1703 / PIC16F1704 / PIC16F1705 / PIC16F1707 / PIC16F1708 / PIC16F1709 / PIC16LF1703 / PIC16LF1704 / PIC16LF1705 / PIC16LF1707 / PIC16LF1708 / PIC16LF1709 are added to Model2000+ / Model5000. MC68HC908JK3 / MC68HC908JK3E /MC68HC908JK1 are added to Model 5000. MD25D10/MD25D20/MD25D40/MD25D80/MD25D16 are added to Model2000+ / Model5000. HN58C65 write bug is removed.
с Новым годом по старому стилю господа!
| Admin | Дата: Четверг, 2016-01-21, 08:56 | Сообщение # 42 |
| Version 9.59 (Jan 21, 2016): MX29F1615 / MC9S12Q128 are added to Model5000. AFND5608U1 is added to Model2000+. R8C/34W X Y Z P R E Series connection message text is corrected (MsgmR8C34.txt,MsgmR8C34C.txt). S29GL128N11FFI01 /S29GL256N11FFI01 / S29GL512N11FFI01 BGA64 are added to Model 5000 (Adaptor distributor link: www.willem-ua.com/shop/585/desc/bga561-5000-solder)
| Admin | Дата: Вторник, 2016-02-02, 16:25 | Сообщение # 43 |
| Обновление основного софта программатора TNM5000 и TNM2000
Version 9.60 (Feb 2, 2016): S9S12HY32 / S9S12HY48 / S9S12HY64 / MC9S12XHZ256 / MC9S12XHZ384 / MC9S12XHZ512 / S9S12HZ128 / S9S12HZ256 are added to Model 5000.
| Admin | Дата: Среда, 2016-02-03, 12:00 | Сообщение # 44 |
| Обновление NAND софта программатора TNM5000 и TNM2000
Nand Programmer Software version 6.00 for Model 5000 (Feb 3,2016) TH58NVG4S0FTAK0 / TH58NVG3S0HTA00 / TH58NVG3S0HTAI0 are added. TC58DVG3S0ETA00 / K9GAG08U0D bug fixed.
| Admin | Дата: Суббота, 2016-04-16, 12:00 | Сообщение # 45 |
Скачать программное обеспечение основного софта программатора TNM2000 и TNM5000 Version 9.62 (April 16, 2016)
Version 9.62 (April 16, 2016): ITE IT8xxx EC Controller series are added to Model5000: IT8585 / IT8586 LH28F128BFHT-PTTLT1A is added to Model5000. C8051F31x Bug is removed. Atxmega long startup detection problem in model 2000 is fixed. ATMEGA328P autodetect corrected. HN58C256 write bug is removed.
