Выход новых обновлений софта программаторов TNM 2000 TNM5000
Nicks777 | Дата: Вторник, 09.12.2014, 01:16 | Сообщение # 16 |
| Admin, Вышла 9.33,
Admin | Дата: Вторник, 09.12.2014, 09:31 | Сообщение # 17 |
| Version 9.33 (Dec 8, 2014)
IC 74HC590 is added to Digital tester of all Models.
BS62LV1024(SRAM tester) , W78L812A , W78LE812 are added to Model 5000. uPD23C32340 / uPD23C32348 / uPD23C64340 / uPD23C64380 are added to Model 5000 /2000+.
R8C/24 R8C/25 series: R5F21244S / R5F21245S / R5F21246S / R5F21247S / R5F21248S / R5F21254S / R5F21255S / R5F21256S / R5F21257S / R5F21258S are added to Model5000.
MX29V3211(SO44) / TC89101P / TC89102P / TC89121P / TC89122P are added to Model 5000. MT29F2G08ABAEAWP / MT29F2G08ABBEAWP are added to Nand Programmer Software version 5.91 for Model 5000. R8C22A/23A ISP connection help text corrected.
89S52 / 89S51 PLCC4 bug started from version 9.11 is removed in Model 5000.
roboc0p | Дата: Вторник, 09.12.2014, 12:22 | Сообщение # 18 |
Admin | Дата: Вторник, 23.12.2014, 08:31 | Сообщение # 19 |
| Новые обновления софта.
Nand Programmer Software version 5.91 for Model 5000 (Dec23,2014) MT29F2G08ABAEAWP / MT29F2G08ABBEAWP / K9K2G08U1A / TC58NVG2S0FTA00 / H27U4G8F2DT / H27S4G8F2DT LGA-52 BGA Packages: K9K8G08U1A / K9K8G08U1M / K9L8G08U1A / K9LAG08U1M / K9K4G08U1M TC58TEG5DCJTA00 / TC58TEG6DCJTA00 / TC58TEG7DCJTA00
Version 9.34 (Dec 18, 2014) IC 74HC590 is added to Digital tester of all Models. BS62LV1024(SRAM tester) , W78L812A , W78LE812 are added to Model 5000. uPD23C32340 / uPD23C32348 / uPD23C64340 / uPD23C64380 are added to Model 5000 /2000+. R8C/24 R8C/25 series: R5F21244S / R5F21245S / R5F21246S / R5F21247S / R5F21248S / R5F21254S / R5F21255S / R5F21256S / R5F21257S / R5F21258S are added to Model5000. MX29V3211(SO44) / TC89101P / TC89102P / TC89121P / TC89122P are added to Model 5000. R8C22A/23A ISP connection help text corrected. 89S52 / 89S51 PLCC4 bug started from version 9.11 is removed in Model 5000.
Admin | Дата: Вторник, 03.02.2015, 20:16 | Сообщение # 20 |
| Новое обновление софта.
Version 9.37 (Feb 3, 2015) AT90PWM1 / AT90PWM81 / AT90PWM161 / AT90PWM2B / AT90PWM3B/ AT90PWM216 / AT90PWM316 / LE25FW056 / S25FL132K / S25FL164K / 25Q64FW are added to Model2000+ /Model 5000. F59L1G81A / F59L2G81A / F59L4G81A are added to Model2000+. MC68HC08AB32 / MC68HC912DG128 / W78E585A / R5F61725S / R5F61727S / R4F2117 are added to Model5000.
Kodov | Дата: Пятница, 20.02.2015, 11:13 | Сообщение # 21 |
| Вышла новая версия Nand Programmer Software version 5.92 for Model 5000 (Feb16,2015)
Admin | Дата: Пятница, 20.02.2015, 11:20 | Сообщение # 22 |
| Новое обновление софта для Nand
Nand Programmer Software version 5.92 for Model 5000 (Feb16,2015) S30ML02GP,S30ML01GP, S30ML512P, S30ML256P, S30ML128P, K9GAG08U0E , K9GAG08U0F , AFND5608U1 , HY27US08121B , HY27US08122B , HY27US08121A , K9F5608U0C и другие добавлены.
Admin | Дата: Вторник, 17.03.2015, 10:17 | Сообщение # 23 |
для Nand
Nand Programmer Software version 5.94 for Model 5000 (March 17,2015) MX30LF1G08AA / MX30LF1G18AC / MX30UF1G18AC / MX30LF1208AA / MX30LF2G28AB / MX30LF4G28AB / K9LBG08U0E / K9HCG08U1E / TC58NVG0S3ETAI0 / TC58NVG0S3HTA00 / TC58NVG0S3CTA00 are added. и другие добавлены.
Для остальных микросхем, основной софт Version 9.40 (March 16, 2015)
Renesas V850ES DJ3 / DL3 Series uPD70F3421 ( D70F3421GJ ) / uPD70F3422 ( D70F3422GJ ) / uPD70F3423 ( D70F3423GJ ) / uPD70F3424 ( D70F3424GJ ) / uPD70F3425 ( D70F3424GJ ) / uPD70F3426 ( D70F3426GJ ) / uPD70F3427 ( D70F3427GJ ) are added to Model5000. Renesas M3062LFGP is added to Model5000. Renesas M16C / 30P Series M30302FAP / M30302FCP / M30302FEP / M3030RFDP / M30302GAP / M30302GCP / M30302GDP / M30302GEP / M30302GGP are added to Model5000. Renesas R32C / 110 Series R5F64110DFB / R5F64111DFB / R5F64112DFB / R5F64114DFB / R5F64115DFB / R5F64116DFB are added to Model5000. Renesas R32C / 120 Series R5F64206 / R5F64207 / R5F6420A / R5F6420B are added to Model5000. Renesas R32C / 121 Series R5F64216 / R5F64217 / R5F64218 / R5F64219 / R5F6421A / R5F6421B / R5F6421C / R5F6421D are added to Model5000. Renesas R32C / 102 Series R5J64026 / R5J64029 are added to Model5000. Renesas R32C / 116 Series R5F64165 / R5F64166 / R5F64167 / R5F64168 / R5F64169 are added to Model5000. Renesas R32C / 117 Series R5F6417B / R5F6417A / R5F64175 / R5F64176 / R5F64177 / R5F64178 / R5F64179 are added to Model5000. Renesas R32C / 118 Series R5F64185 / R5F64186 / R5F64187 / R5F64188 / R5F64189 are added to Model5000. Renesas R32C / 116A Series R5F6416JA / R5F6416KA / R5F6416LA / R5F6416MA are added to Model5000. Renesas R32C / 117A Series R5F6417JA / R5F6417KA / R5F6417LA / R5F6417MA are added to Model5000. Renesas R32C / 118A Series R5F6418JA / R5F6418KA / R5F6418LA / R5F6418MA are added to Model5000. Renesas R32C / 142 Series 5F6442F / 5F6442H are added to Model5000. Renesas R32C / 145 Series 5F6445F / 5F6445H are added to Model5000. Renesas R32C / 151 Series 5F64514 / 5F6451M / 5F64515 / 5F6451N are added to Model5000. Renesas R32C / 152 Series 5F64524 / 5F6452M / 5F64525 / 5F6452N are added to Model5000. Renesas R32C / 153 Series 5F64534 / 5F6453M / 5F64535 / 5F6453N are added to Model5000. ATTINY261 / ATTINY461 / ATTINY861 / ATTINY441 / ATTINY841 are added to Model2000+ / Model5000. W25Q256(SO16) AutoDetect is Fixed. KB9010 / KB9022 are added to Model5000. S25FL132K / S25FL164K Security registers are added. S29GL512R / S29GL01GR Series are added to Model2000+ / Model5000.
sulmas | Дата: Вторник, 17.03.2015, 20:11 | Сообщение # 24 |
| Admin, Отличные Апдейты, Спасибо !
serg2000 | Дата: Воскресенье, 19.04.2015, 10:06 | Сообщение # 25 |
| Что то затихло все с обновами
DeCodeR | Дата: Воскресенье, 19.04.2015, 11:35 | Сообщение # 26 |
| в Иране национальные праздники вроде были. Они как Китайцы, месяц - полтора не работают
Admin | Дата: Воскресенье, 19.04.2015, 12:30 | Сообщение # 27 |
| Ребята, будет обновление. Не торопитесь. Торопится нужно не спеша. А ввиду запроса в поддержку большого количества микросхем , обновление моментально не выйдет.
Большинство из запрошенных, будет добавлено в этом обновлении, а это работа, требует времени.
DeCodeR | Дата: Понедельник, 11.05.2015, 21:13 | Сообщение # 28 |
| давненько апдейтов не было... раньше как то быстрее тех.поддержка реагировала
Admin | Дата: Понедельник, 11.05.2015, 21:13 | Сообщение # 29 |
| DeCodeR, читаем выше пост.
Admin | Дата: Четверг, 14.05.2015, 18:23 | Сообщение # 30 |
| Тему почистил. тролля DeCodeR, отправили в бан.
Обновление, будет в течении трех четырех недель. т.е в течении месяца. Ожидайте.
