K9GAG08U0E copy
satelitkoДата: Вторник, 2017-01-03, 01:31 | Сообщение # 1
Trying to copy this NAND from working SAMSUNG LED TV, but no success.
My procedure: working IC put into programmer, autodetect, read, save file to disk.
New IC put into programmer, erase, write file from disk. Verification not pass.
What am I doing wrong?
Thanks in advance, Gregor
AdminДата: Вторник, 2017-01-03, 13:17 | Сообщение # 2
Статус: Online
Good day.
check the contacts of the chip. Clean well the chip terminals.
try to run after recording a TV and update the firmware by standard means.
satelitkoДата: Вторник, 2017-01-03, 14:19 | Сообщение # 3
I do not think that contacts are the problem, since auto detection work fine.
TV does not start at all, It cycles again and again, as without NAND IC. cry
Does the TNM500 automatically handle the bad blocks in the original and in the copy IC?
What exactly happens if "Read chip and correct info" is selected?
Thanks for your willing to help!
AdminДата: Вторник, 2017-01-03, 14:27 | Сообщение # 4
Статус: Online
where the firmware file is taken?
if it is read from the old chip, it is likely that the dump is corrupt.
You need to find a good flash dump, a matter with the serviceable TV.
satelitkoДата: Среда, 2017-01-04, 11:12 | Сообщение # 5
Firmware is taken from a currently working chip. (problem with this TV is, that from time to time it just does not start properly - at the moment it is OK).
I am just trying to make a "hard copy" of working chip.
Добавлено (04.01.2017, 10:12)
Now I noticed, that after I read a working chip and then do a "verification" already get some mistakes. How is this possible?
Danila_ivaДата: Четверг, 2017-01-05, 23:12 | Сообщение # 6
the feature of multi-level nand flash
this topic has been raised... for a different chip but the essence is the same
the more time worked device the more failed cells and slower to download and work.. and that's not counting bad blocks
http://www.willem-ua.com/forum/34-587-1
vagnerДата: Суббота, 2017-08-19, 12:49 | Сообщение # 7
K9GAG08U0E http://***************
[texterror1]рекламная ссылка. спам. бан пожизненно.[/texterror1]
© Willem-UA 2010–2025
