tnm5000 help K9F4G08U0D
rtn | Дата: Среда, 2018-06-13, 21:13 | Сообщение # 1 |
| hi all problem writing and deleting Nand K9F4G08U0D
Chip 0 ID:9510dcec Chip 1 ID:ffffffff Chip 2 ID:ffffffff Chip 3 ID:ffffffff Deselect ReadBack:ffffffff ONFI string: ìÜ Model: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Page Bytes + Spare : -1 + 65535 = 65534 Number of Pages in Block : -1 Number of Blocks in chip : -1 Number of Chips : 255 Column Addresss Cycles : 15 - Row Addresss Cycles : 15 Bytes per Partial Page : -1 Bytes per Partial Page : 65535
Start Erasing... x Erase Error in total 1 Blocks.
Erase Error in total 1 Blocks. Start Programming With Verify 540672 Kbytes from File: C:\Users\RTN ....x Help me thank you
groff | Дата: Четверг, 2018-06-14, 11:48 | Сообщение # 2 |
| It's normal, you have 1 bad block. It can't be erased or programmed. See Help in app. X mean bad block.
rtn | Дата: Четверг, 2018-06-14, 12:32 | Сообщение # 3 |
| Hi, thanks for answering me but, I do not know how to solve could you help me please
groff | Дата: Четверг, 2018-06-14, 15:07 | Сообщение # 4 |
| First erase, than programm and try it in device. If bad block doesn't contain important data it will be OK. It's must work with that 1 bad block.
groff | Дата: Четверг, 2018-06-14, 18:39 | Сообщение # 5 |
| Цитата maybe you have to set it in DEVICEDEFN.TXT you know how I can do it
I don't know. You can try with lower frequency in config. Clean all pins on adapter and chip with alcohol.
Сообщение отредактировал groff - Четверг, 2018-06-14, 18:48 |
groff | Дата: Четверг, 2018-06-14, 19:13 | Сообщение # 6 |
| He's on the forum here, too.
Цитата .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x Program verification error in total 3 blocks.
I had the similar screen like you with different chip but it work in my device.
Сообщение отредактировал groff - Четверг, 2018-06-14, 19:16 |
groff | Дата: Четверг, 2018-06-14, 19:25 | Сообщение # 7 |
| I didn't do anything, programmed like on screen at you, and it work in device.
